Gonna try and compile this so it will help people choose a lift and maybe a tire to go with it.
1. Rustys 4.5" lift Price: $1,550.00
4.5"
A lifted WK or XK will clear 33½ tall rubber, depending on wheel width and offset. The V-8 equipped Jeeps (especially the Heims) will have no problems pulling this size tire, even without a gear ratio change. i think they just copied that from superlifts web site
http://rustysoffroad.com/mm5/mercha....mvc?Screen=PROD&Store_Code=rustys&Product_Code=RK-450A-WK&Category_Code=WKKITS
2. Super Lift
4" Lift System
A lifted WK or XK will clear 33½ to 34½ tall rubber, depending on wheel width and offset. The V-8 equipped Jeeps (especially the Hemis) will have no problems pulling this size tire, even without a gear ratio change.
http://www.superlift.com/Catalog.asp?V=281&P=K864
3. Rock Krawler 3.5 Inch X Factor System... Suggested Retail: $349.00
3.5 Inch
Allows for 31 Inch Tires with no Fender Trimming or 32x11.5's with Minor Fender Trimming. Shown with 33x10.5R17 SSR's (265/70R17 SSR's) on 17x9 Helo Max 6 Wheels with 4.5 Inches of Back Space.
http://rockkrawler.com/
4. Rocky Road 2.25" $250
2.25"
We've received many questions on tire sizing with this lift.
The answer is.... there is no single answer. Wheel size and backspace can make as much or more of a difference as tire size. The design of the knuckle assembly makes it close quarters width-wise for oversize tire fitment
265/70R17 depending on tire
5. Old Man Emu 2" around $800
2" medium and heavy duty depending on load
These systems include front and rear coil springs, and Emu Nitrocharger shock absorbers. This system will allow fitment of 31” tall tires for maximum performance.. Many forum member have this lift and love it.
http://www.quadratec.com/products/76090_60X_PG.htm
6. Rustys budget 2" lift Price: $159.00
2"
Rusty's WK budget boost is a proven way to get your vehicle up for extra ground clearance and to clear oversized tires. The Rusty’s kit consist of two strut spacers in the front, two poly spacers in the rear.
http://rustysoffroad.com/mm5/mercha....mvc?Screen=PROD&Store_Code=rustys&Product_Code=RK-BB20-WK&Category_Code=WKKITS
7. Day Star leveling kit $153.55
2"
ComfortRide™ Suspension Coil Spring Spacer Kit
High Density Progressive Polyurethane
Lifts Vehicle Without Sacrificing Ride Quality or Load-Carrying Capacity
Easiest Way to Add larger Tires & Wheels
Maximum recommended tire size: 31"
Improves Ground Clearance
Limited Lifetime Warranty
Includes Front Strut Spacers, Strut Plates and Rear Coil Spacers
http://www.daystarweb.com/productdetail.php?productID=373
8.Bilstein HD shocks $300 for all 4
3/4"
3/4" lift and will stiffen the ride.
www.summitracing.com
BSN-24-029636 is the part number for the fronts
BSN-24-029643 for the rears
please let me kno on other lifts and ill add them:thumbsup:
4.5"
2. Super Lift
4" Lift System
3.5 Inch
2.25"
2"
2"
3/4"
