I did the whole thing from abs to rear control arm but in 2 pieces instead of 1 and nowhere near all those funky factory bends.
1. 1 6' section of standard 3/16" standard brake line.
2. 1 5' section of 3/16" standard line with a bubble flare adapter for the abs side.
3. 1 3/16" union(specify union not compression fitting)
Tools: You need a good quality double flaring tool like Craftsman etc.No auto parts store or Harbor Freight cheapie(found this out the hard way),tubing cutter,top quality wrench set(preferably line wrenches)brake fluid,pb blaster and a brake bleeder or buddy to help bleed the brakes.
Do the longer rear section first. You should be able to bend it to fit in all the original clamps. It should end in front of the tranny cross member which is a good accessible place for the union. Install the bubble flare adapter in the abs. Now do the top piece from the abs to your new line using the old line as a rough pattern for a few bends up top to get it heading down along the firewall.You don't need all those funky bends along the frame rail just straight down to your other piece. Try to hit at least 1 clamp though. Once you make it to your rear line cut of the excess from the front line,PLACE THE FITTING FROM THE CUT OFF PIECE OVER THIS LINE AND
THEN FLARE IT!!
Install the union bleed the brakes and have a beer!
