We've replaced the air control valve [jeep] with no results, chk. engine light still comes on, code 0505. Just installed another same results. Does anyone think poss. ground issue? Do have fuel gauge failure, bought that way, replaced complete pump assembly, still no fuel gauge. Tried another dash to see if that gauge worked but does not, it is from my wife's totaled GC. and it does work, but not in my sons which is where the problem is. I'm guessing ground somewhere. I have run new grounds, engine to body, body to battery, cleaned existing grounds. Still neither problem is solved. Sure could use some help. Thanks in advance.
