Hey all...well I gave up with the 'key dance' to try to get codes..wouldn't work, so I got a Innova code reader. Here's the codes:
P0300 random misfire
P0132 O2 Sensor Circuit High Voltage Bank 1 Sensor 1
P0158 O2 Sensor Circuit High Voltage Bank 2 Sensor 2
Symtoms : Start Jeep, and runs really rough at Idle and MIL flashes, and worse in gear for a minute or two, then seems to settle down, and I can drive it no problems. Only happens when I first start it...but notice when i go to park after a drive, it idles at around 500 rpm. MIL stays on (not flashing) throughout trip.
I cleared the codes with my Code reader, and ran the truck again (to see if it would run the same codes)...no problems at all...ran fine and the MIL stayed off. Took the truck on another trip about another hour later, again, ran fine and no MIL. Ran the truck again an hour after that, and it started fine, and ran ok, but the MIL came on about halfway (5 minnutes) into my trip. When i got home, I ran rhe code reader again, and got the same codes as above.
I have already changed and gapped the plugs (NGK platinum)...but an at a loss as to what could be setting off O2 sensor codes on 2 different banks??? I've also ran a tank of 93 octane gas...
I've looked through the forum and found that some have had luck with 'Seafoam'ing the engine (where in canada can I get that?) or by changing the Crank Sensor...
Any ideas before I throw a bunch of parts at this?
Greatly appreciate any help!
Thanks in advance..
PK
Thanks in advance..
PK
