21 - 40 of 41 Posts
Experiencing the same issue right now. 2021 grand Cherokee. Replaced both batteries and blower motor resistor. The issue came back 1 hour later. Next step, blower motor assembly itself. Hopefully that fixes it! I’ll keep you posted!
Also experiencing a noisy engine whine consistent with accelerating. Anyone have that???
Update: so far I’ve replaced both batteries, blower motor resistor, and blower motor assembly. Worked for 8 minutes on test drive. Then lost blowing air. It is NOT specific to a/c or heat. Rear vent follows suit. I am at a total loss. Also getting a “whine” that follows acceleration, started at the same time. Also, a hissing/vacuum noise at the dash/back of motor long after I shut the vehicle off. Any thoughts anyone? 2021 Grand Cherokee 3.6l WK2
My 2019 Jeep Grand Cherokee Limited has the EXACT SAME symptoms to a T. So far they have replaced heater coil/condenser, both batteries, alternator. It’s at the dealership now. It has them scratching their heads. About $3,500 so far and nothing has changed. So frustrated. I love my Jeep. I have 213k miles and no major issues other than the normal wear and tear.
So just wanted to say I dealt with this same exact issue for 8 months on my '19 JGC Overland. Dealership looked at it twice with nothing. It definitely was not the blower as I could hear it bump up in speed when turned up to lvl 7. Simaltaneously I was also having the battery drain till it was just crazily needing jumped if not started again after 8 hours. Both batteries replaced. Same issue. Then I decided to disconnect both terminals and wrapped them of the start/stop battery. After running with this for a week, the issue (after 8 months of consistely being this way) it magically just stopped happening. BOTH ISSUES. It's been doing great for 3 months now (knock on wood). During all of this, I even performed the drain tests myself. Could not find the issue at all going through ALL fuses, etc. I'd never seen anything like it and the dealership was outright confused. I hope this helps spread that magic for you all!
I have had this same issue with my 2018. I've replaced the hvac control module and actuators and nothing fixed it. I didn't think the evaporator was freezing. I've been driving around with the hvac system off, I went to add washer fluid and noticed the ac lines to the compressor were frozen. Ive also had my battery die on me twice. After a quick diagnosis I found that my ac compressor clutch was engaged all the time even with hvac system off. Pulled the fuse for the compressor clutch and it disengaged. The compressor clutch staying engaged will also explains the parasitic draw on the battery. Luckily where I live it's getting cooler so this has bought me some time to figure out what is telling the clutch to stay engaged.
The compressor relay which is internal to the PDC is likely staying latched. If so, a new PDC will be needed.
It seems to work just fine if i also stay at a lower speed but once i get on a high way thats when it starts to fail. The system works fine and gradually slows down and then stays consistently at a low near noticeable speed. It's never stops completely.
I'm pulling the battery tomorrow and putting a new one in. I'm gonna charge and test the battery myself to see if that's the issue.
I'm dealing with the exact same issue right now hectic the Florida heat
Have you had it fixed eventually?
Same here, I just had my AC/AIR system fail driving in Florida. Sounds identical to the original post. I turned the system off for the remainder of the 2 hour drive, and when we got to our destination I turned it back on and got full air flow and cold air... I also notice what sounds like the AC compressor constantly making adjustments, like a wooshing sound while driving or stopped. Does your system make that noise as well?
That sounds like a low system charge. I would get it checked.
Same issues here...2019 Grand Cherokee...blower failed two hours into a drive, started working fine last night/this morning. Today it went out again on a long drive home...car has been off for two hours, just went and checked and it seems to be blowing now although not at full power...seems to be a pretty common problem by the sounds of it.
Add me to the list (‘18 TH 97k miles). Like the OP, I’m also in Western PA and this couldn’t have happened at a worse time as we’re now in 20*/30* temps.
Before it actually died like this today, I’ve been noticing it has been taking longer for the fans to turn up - maybe even a minute or two - but at least I had heat. I’ve also noticed the HVAC hasn’t been as silent recently which seemed like it was the fan, but I just chalked it up to being high miles and could live with it since basically sounded like a fan from a car build in the early 00’s or something.
Not sure if those details may help someone in the future. I’ll be trying to find a fix ASAP; the very least just have some heat and defroster.
Glad to hear I'm not the only with this weird issue. 2020 GCG, 108K miles. Zero air coming out of vents no matter the level. No sound, no whooshing, nothing. Then, it will work next time I'm driving. Really don't want to a huge repair bill to so waiting to see if it continues.
Update for mine… I went through the basics for this issue that others have tried - checking wiring, checked fuses, checked fuse box connectors, etc and all was good.
Because I hate electrical diagnosis, I’d rather throw parts at it and see what sticks. I ordered a Four Seasons blower motor from Rock Auto and tossed it in. Super super quick and easy repair - access is right there, three screws and a connector and drops right out. Fingers crossed and success!
It’s been about two weeks since I did the repair, so I didn’t want to get too excited in case whatever might have been happening fried it. But we’re still going strong.
So there is hope here guys!
I’m going crazy with this too. What do you means when you said that “wrapped them of the start/stop battery”. I have changed the resistor twice and nothing.
to stay away from the proverbial parts cannon I would:
scan it to see what codes might come up, of course you need a scanner that can scan all modules, I have fixed a couple of mysterious electrical issues on my '07 WK-1 that way, those 2 repairs alone, paid for the scanner!
Has anyone noticed if this occurs during or soon after a drive in wet weather?
My 2019 had this issue for a few years and it was always after a wet weather drive, making me think it is some kind of short?
I had it all replaced under warranty and so far fingers crossed, but I cringe every time I have a drive on wet roads.
Good luck.
My wife's 2014 GC Limited has issues. All of the center stack buttons under the touch screen stopped working a year ago. Since then, we've been using the touch screen to control the climate control and other functions. A month ago, it stopped blowing cold air 50% of the time but the fan still worked. Now the fan doesn't even come on. I've fixed AC issues on older cars. I hooked up my AC manifold gages and the high & low pressures were in range except the low side wasn't moving at all. I've never seen that.
Took it to a mechanic and he couldn't find any codes and suggested I take it to the dealer for a possible update fix. Dealer looked at it for $245 and didn't see any codes but says that a new center stack might fix the issue for $1,800. I know there is a reset procedure by pressing and holding the 'Volume" and "Browse/Enter" that can't be done without fixing the buttons. Dealer said that the center stack controls the HVAC, but I found out that the 2014~2015 GC has a HVAC module behind the radio.
I'm leaning towards finding and installing a used center stack myself. Then trying the reset procedure. If that fixes the buttons and not the AC, at least I can then bring it back to the dealer and act like the buttons started working. Maybe they'll figure out the issue without me spending $1800 on buttons.
21 - 40 of 41 Posts
