a lock pick on your 2011 JGC? Does it work and how hard is the install?
thats what the lockpick is for!Does anybody know if you can still listen to a DVD while driving or does it completely disable the DVD drive when not in park (i.e. concert dvd's, etc) ?
You are right, it is pretty tight. Any tricks other than taking my time? Did you use a trim tool? Thanks.Install was fairly easy. Hardest part was getting the trim around the radio off. Unlike past jeeps this one is tightly installed. Be careful take your time and work it out a little bit at a time. As far as the actual lockpick it was easy plug an play. Also there is plenty of room between my nav and the ac control unit to Zip tie the lockpick unit into place.
Lockpick sounds awesome! I'm going to order one today-I used a thin somewhat flexible plastic putty knife (the kind for patching drywall the ones you usually use and toss out) about 2 inches wide. I was able to slide it between the trim and the dash on the top and work it out slowly from there without damaging the dash at all.
After reading this thread I just ordered the Lock Pick for mine. I have the 430N RHB system. I am mainly after movie video and NAV control while not in park. The rear camera would be fun so I will see what is involved in getting a wire from it up to the unit.
Thanks for the good info.
The front is a radar type system as I understand it. You would need to add an additional camera up front if you wanted to use that feature.I see on the website it says front camera activation. Would this mean it would work with JGCs with tech package somehow? Although I think the front camera is actually a sensor.
