My OE battery on our JGC ED decided to go TU after 6 years......Texas and towing can be hard on batteries, even if you keep them on a BT.
I replaced it with an Autocraft Platinum H8 from Advance Auto for $175, net with the exchange and a coupon plus I bought a 9v battery Memory Keeper from Amazon for $11.62 shipped via Prime, making the R&R of the old battery fairly painless.
I pushed the Passenger seat all the way up, then all the way forward, which gives you plenty of room to work. And you WILL need to lever the two forward fasteners on the battery cover. In my case I used a long flat screwdriver, placed it adjacent to the fasteners and simply twisted it up and they both pulled out easily afterwards.
For the Memory Keeper I used the Center Armrest Cig Lighter Plug, as it is always "Hot" (on). Once I had that plugged in, I went ahead and removed the battery.
You will need a 10mm for the battery clamps and a 13mm with a 12" extension for the battery hold down bracket. I carefully removed the vent hose (don't pull it hard and out of the frame grommet!!!) , removed the Negative clamp and then tied them both up to the RH seat frame bracket, out of the way. I then removed the POS terminal and did the same but covered it with a plastic storage bag first!
The Battery can be pulled out and lifted, using both hands with one hand (and using the handle on the battery) to Pull it toward you and up to over a 45 degree angle, then, using the other hand underneat it, to simultaneously lift it over the back lip of the battery box. Installation is much easier........Slide the new battery down and hold it from falling by using the battery handle. I used 9Nm for the battery clamp torque and 10Nm for the battery holddowns. The instructions for the battery swap and torque setting are on the bottom of the battery tray cover.
I then removed the 9v Memory Keeper, pressed the magic start button and everything worked just fine and Dandy!
Much easier than I anticipated........
