Charging A Battery In Place On A WK2 Jeep Grand Cherokee ?
3 reading
48K views 88 replies 32 participants last post by  schmieg
I know you can jump start them off the positive and negative jumper posts under the hood. But what about using a battery charger or maintainer on them? Have any of you charged your battery located under the seat, from a battery charger hooked up to the jumper posts? Did everything work out OK? And what amperage charger did you use?
I have read that AGM batteries like a higher amperage charging rate, than standard flooded lead acid batteries do. Which is why I asked about the charging rate. I was thinking of doing this from time to time, to keep my battery in a fully charged state, because my Jeep sits for several days sometimes. And it's always better for your battery to remain fully charged as much as possible... Thanks in advance.
#2 ·
Yes, I charge my battery from the battery posts under the hood. Works fine. Getting under the seat seems a bit of a pain. I also fully charge the battery after not using the car for a few days. The car relies on a good battery charge for so many functions, and many issues arise from low battery charge, and there is a parasitic drain all the time. Cheers.
#18 ·
If you are talking about the small ring connectors that attach directly to the terminals with a screw, may I ask how you connected them? I would like to do this so I don't have to keep opening the hood, and screw around with the alligator clamps all the time. But I don't see any screws or attachment points for the eyelets.
#9 ·
This morning I hooked up the charger and set it on AGM, at 8 amps. And ran it for 2 hours. I then hooked up the Battery Tender Jr. And it flashed green for about 10 minutes, then went to solid green, (float setting).
So tomorrow I'll test it after it settles down, and see where it's at. It should be at or near 100% charge.
#10 ·
Ignorant question: what is the difference between a battery tender and a portable jump charger, such as an Anker? I have an Anker that I have used on another vehicle to jump start, but is that the same thing to use as a charger? There is a light indicator on it that changes from red to green before I jump start. Thx!
#11 ·
A Battery Tender only puts out 700 milliamps, or 7/10 of one amp. The portable jump starters can put out several thousand amps. Albeit for a very short time. Enough to get your vehicle started. The Battery Tender is designed to prevent the battery from discharging on it's own from sitting, or from parasitic draw.
#55 ·
I also have been using Battery Tenders on my vehicles for almost 20 years and have never had an issue with the Batteries connected, or the other electronics of the vehicles, including my '09 Grand Cherokee Limited 4x4..
It is easy using their connectors and getting longer cables with them, to hook up to the battery and then just find the connector end wherever you placed it, and plug in the Battery Tender when you park the vehicle...
My Batteries also go years and years without problems...Float Chargers are easy on the Battery..
#16 ·
I only use a battery charger for AGM batteries. I use the terminals under the hood with no problems and fully charge my battery at least once a month overnight. this program keeps everything happy including the secondary battery for the Start /stop system on the newer 3.6L V6's. AGM batteries like slower charges as opposed to a rapid charge.
#19 ·
I spent some time looking under the hood, trying to find a way to route the Battery Tender lines out through the front grille. It's not easy. They have the entire front of the vehicle sealed off, so all of the air entering the grille has to pass through the radiator. There are no openings to route the wire leads through, and out to the front of the grille.
Both the positive and negative charging posts appear to just unscrew from the threaded studs. Which makes connecting the ring eyelets of the lead Battery Tender wires easy. But trying to route the wires is going to be a challenge.
#26 ·
Keep in mind that the positive boost post is directly connected to the battery. It is best to disconnect the negative terminal on the battery while you're working on the boost post. That way, you'll avoid unexpected fireworks.
#21 ·
Both functions are exactly why those posts are conveniently available under the hood of the "WK2" design.
#22 ·
Just on a related note----most of the modern smart chargers will fully charge your battery and then continue to trickle charge them as needed, just like a dedicated battery tender does. So you can keep them connected to the battery pretty much forever if you wanted to do that. I have a CTEK that I use like that for a car that I don't often use in the winter months.
#33 ·
I was wondering, but I never tested it. Will a WK2 Jeep Grand Cherokee allow you to put the transmission selector into reverse or drive if the hood latch is popped? I know the remote start feature won't engage if the hood is open.
I see where there is some wiring going to the hood latch. I don't think you can move the transmission selector out of Park, if the hatchback is open as well.
#38 ·
One feature to look for in smart chargers is a "12 volt supply" mode. While that seems like something that is just nice to have, it does have an important benefit. Most smart chargers have a fair amount of protection built in. One of those protections Is that the charger won't start charging unless it detects a certain battery voltage when connected. That's typically between 2 and 4 volts. The problem with that is that if you have a badly discharged battery, you can't charge it. With a "12 volt supply" mode, you can force some charge onto the battery and bring up its voltage enough that the regular smart charge mode will work.
The newer Noco chargers have gone one better with a "force mode" which automatically switches back to a charging mode.
#40 ·
I have couple of NOCO Genius battery maintainers and also an old Battery Tender Plus. Recently, I purchased a NOCO GC003 accessory (pic below). I have the battery maintainer mounted on the wall right next to my Jeep.
I drive into the garage, open the driver side window, reach out and plug this to the "cigarette" lighter in the center console because it is always powered even when the Jeep is off. I don't need to open the hood using this accessory.
#41 ·
I like this. Please elaborate because I'm not the sharpest knife in the drawer when it comes to electrical systems in cars. Are you saying that with this "cigarette lighter adapter", you are charging your battery, by reversing the flow of power through the cigarette lighter port, back into the battery?
Does this effect the operation of the charger in any way? By that I mean will it still sense a full charge and go into "Float Mode" the same as if you were charging from the jumper posts?
#60 ·
I use Optimate battery charger/maintainers. I select the models than can charge / maintain the most battery types and have a few that can restore weak or dead batteries. I have 9 chargers that I use continuously on seasonal equipment, snowmobiles, golf cart, diesel mower/tractor, SxS, and always have a few extra that I can lend or give as appropriate. I have batteries that are 8-10 years old and are still serviceable on equipment that are used at least weekly during their active season. And yes I use the under hood charging adapter for my Jeep and my 2009 Journey that current.has 206,200 miles. The Optimate 1’s are the equivalent of battery tenders but typically seem to do a better job of maintaining batteries without damage due to over charging through the use of float charging. And I have never had one fail in he 15 years I have used them.
