Hello everyone! I bought my 06 wk 3.7L at auction for a steal about 6 months ago. I had my engine light up a couple weeks ago with cylinder 5 misfire! The first thing I did was change the plugs and when I did I noticed that the coil boot on #5 had oil on the bottom as well as the plug. I swapped boots with #1 and got the codes reset. I noticed the rpm's did not die at the same range as before but now has a rough idle and starting acceleration. I bought a new coil boot for #5 and swapped #2 to #1......still getting cylinder 5 misfire! I also seafoamed the whole engine...ie...gas/booster/throttle body, that helped with power but not the misfiring.....any ideas would be awesome!!
