DIY- 2011 Differential Service/ Fluid Change
1 reading
106K views 86 replies 28 participants last post by  jgcrp1
Update: Per dealer, they torque to 15-20lb-ft on the plugs.
It is only mixed if you purchase that part #. If you purchase the other part #, it is not. The difference being weather you buy an extra quart of oil for $50 or the modifier for $6. Per my local dealer, they don't even stock the oil w/ mod because it is less expensive to add the mod separately.
Ok, thanks
