Egr
3K views 8 replies 5 participants last post by  dmsfun
check engine light on had checked at dealer said EGR valve bad.Replaced it and light on again had checked again said EGR bad again. Help:D
#5 ·
did YOU replace the egr valve with an egr valve YOU sourced? or did they perform the repair with a mopar part? If it was the latter, take that crap back and have them warranty it... if it was the former, buy a better part ;)
#9 ·
I've replaced mine twice over the years with a Rockauto EGR as preventative maintenance, no codes were ever present, and it is an easy 15 minute job after having done it before. I doubt the EGR is bad though, since you're seeing the same code after 3 new EGR's.
