I have a 2016 3.6L High Altitude. How do I know if I have Standard Cooling or HD Cooling? Trying to determine if I have 3,500# or 6,500# towing capacity. Thank you.
This particular thread is only two days old as of "this moment".I know this thread is over a year old
That has never been the case since this platform debuted in late 2010. The package itself varies by year, trim and engine for certain components.So I'm guessing either the trailer tow group IV was available for dealer install
"NMCP Heavy Duty Engine Cooling"The build sheet should specifically list HD cooling. If it doesn't, I doubt locating part #'s will prove any different.
My guess is the Certification is far more than just the strength of the TOW Hitch, after all, it's the same TOW Hitch installed the same way as at the factory, as far as the Hitch is concerned, there is no difference. But safely towing is far more than the hitch being strong enough....The FACTORY INSTALLED Tow Package can only be installed at the FACTORY. Owner or Dealer Installed Hitches are not certifiable to the higher limits.
The HD cooling fan is difficult to retrofit; I believe it requires a different engine-compartment wiring harness... it gets a 100A feed directly from the jump post, and uses PWM control instead of two-relay control.The TOW Group as a Dealer installed option? While the changes are a half dozen components, that a Dealer should be capable of replacing. The cost of the new components and labor rates for the Dealership, really make me think this is impractical and never offered as a kit. The load leveling shocks and 180amp alternator are expensive, and the radiators, fans and springs aren't cheap either, to replicate the changes done at the assembly line would be very expensive at a Dealership, that's my guess. Probably never offered as a kit....
Yep, in fact I was looking at that in a parts catalog, and remember a thread about how the fans operate. The SD Fan had 3 tabs in its connector and what appears to be a coil sensor inside the shroud to sense heat. While the HD fan had two very heavy duty tabs in its connector and no sensors.The HD cooling fan is difficult to retrofit; I believe it requires a different engine-compartment wiring harness... it gets a 100A feed directly from the jump post, and uses PWM control instead of two-relay control.
I'm fairly sure the factory Trailer Tow group does NOT include HD brakes.The HD Brakes, Cooling, Bigger Alternator and I suspect the most important, rear suspension increased spring rate and load leveling shocks are part of the Engineering guidelines used to certify the vehicles to the higher tow ratings. That is not only engineering guidelines for the Hitch Strength, its also the engine cooling, electrical power and braking capacity to handle the higher load. And Suspension that has the correct dynamic characteristics.
MY14+ the HD brakes were packaged with the engine. 3.0 and 5.7 got them, 3.6 did not irregardless of the tow pack.My recollection in '14 was that TrailerTowIV came with HD brakes if they weren't already there for another reason. I haven't looked since then..
What does that involve? And cost?2015 Grand Cherokee Overland 3.6
-Heavy Duty Brake Upgrade
Rotors and caliper brackets in the frontsWhat does that involve? And cost?
The How Too pages has a write up on it, if not more than one.What does that involve? And cost?
Keep in mind both use the same pads, the only difference between SD and HD that would affect performance in most cases is that the front brakes add 10mm to the torque arm of the braking. That is not very much and a performance set of pads would probably more than make up for that.What does that involve? And cost?
Yea, I bet you're right.MY14+ the HD brakes were packaged with the engine. 3.0 and 5.7 got them, 3.6 did not irregardless of the tow pack.
This is correct. HD Brakes are based on what engine the vehicle has.I'm fairly sure the factory Trailer Tow group does NOT include HD brakes.
