Noticed something strange with my battery
1 reading
6.8K views 19 replies 8 participants last post by  grtessman
#1 · (Edited)
So I have four vehicles in my household that are 2016 or newer and all use factory installed AGM batteries. When checking the battery state of charge with a voltmeter, they normally are at about 12.1 to 12.3 volts after sitting for a day. A fully charged, healthy battery should be at 12.6V minimum and even a tiny bit higher for an AGM battery (about 12.7V), yet mine all sit in the low 12's consistently.
My 2019 Jeep sat in the garage all weekend and just for the hell of it, I pulled out my multimeter and got 12.03V. This was measured at the lugs under the hood, not off the battery directly. Then I pulled out my battery tester and the battery came back with plenty of CCAs, even at a low state of charge.
Then I checked the battery on our 2019 Acura RDX, which was just recently replaced, and it was at 12.3V. Then I checked my 2016 Audi, which had a new battery installed last yar, and it too was at 12.3V. I ran my battery tester again on the Acura and the Audi, and both batteries came back with very strong CCA performance, despite beting at a low state of charge.
So this got me thinking---do AGM batteries tend to lose charge more rapidly if a vehicles sits for a day or so? I really doubt all of my vehicles have any parastic draw issues. I'm not sure why these AGM batteries tend to lose charge over 24 hours, but it can't just be a coincidence, right?
#2 ·
As far as I know, all modern vehicles have parasitic draw when not running. The vehicle systems are in low power mode, but something has to be awake to respond to remote door lock controls, remote start, and proximity sensing for the fob.
Put an ammeter on the battery cable when the vehicle is sitting and you will almost certainly see a current that decreases over time, but never goes to zero.
#3 ·
That's true...there's always some parastic draw. But I've been starting to pay close attention to this and it seems like the batteries in my vehicles all drop rather quickly (around 24 hours) to the 12.3V range, but then really won't drop any lower than that even if left unstarted for a few days. Just seems really strange. I can't figure it out.
#8 ·
Yeah, same here. So strange though. No starting issues whatsoever and all the batteries still have really good amperage, but the voltage is low, which indicates a low state of charge. I never had this issue when I had cars that used regular flooded lead acid batteries.
#12 · (Edited)
At lunch today, I went out to my Jeep and checked the voltage reading using a volt meter on the jump start lugs in the engine compartment. It was 12.21V. Then I moved the passenger seat forward and checked the voltage at the battery terminals. It was 12.15V, probably because I used the power seat motor to move the seat. I also checked the small start/stop battery and it was also 12.15V.
I noticed if I held the meter leads on the terminals for a while, the voltage reading would increase .1 volts at a time. It actually increased all the way to 12.3V before it finally stopped. This took about two minutes of holding the leads on the terminals. Again, not what I was expecting.
I'm guessing that both the big and the little battery are connected since they had the same exact voltage, but I'm not really sure about that.
I have my start/stop system turned off permanently, so im not sure if I can just replace the main battery and leave the small one alone since I never use start/stop.
#15 ·
Your Multimeter is not reading right. I have 5 different multimeters and 3 of them read correctly. The only 2 I really trust are made by Fluke. Get another meter and then check again. 12,1V is a dead battery. Your batteries after sitting overnight should read between 12.6-12.7V, It takes a month or more for a computerized car to run a battery down. I quite frequently leave my Honda sit for 3 months while traveling. The parasitic draw on these newer cars is almost negligent.
