Thanks Hobbie - I appreciate the reply. Does the Protech come with all of the application tools (spray bottle, squeegee, micro fiber cloth, etc.) or do you have to buy those separately?
The kit comes complete with all you need. There are some good videos on techniques.
I installed the NAV screen today. What I learned.
1. Work from the top down getting the two small tabs and the edges lined up and in place at the top of the screen. Getting the top locked in makes it easier to do the rest of the screen as you work your way down.
2. Use ample solution. It makes it easier to move around. Make sure you spray the screen and the back and front of the product.
3. If things are not lining up at the top remove the product add more spray and do a restart.
4. You must work top down due to the curves at the top and along the edges.
5. Apply pressure at the corners at the top to get the product to conform to the angles.
6. Same for the edges - apply pressure and work top down as you expel moisture to the sides.
7. Keep applying pressure on the edges as you work down.
8. When you get to the bottom of the screen align the lower corners first and use pressure to get the adhesion to stick.
9. Same all the way across the bottom.
10. Wrap the squeegee in the towel when adjusting the product.
11. Make sure you have plenty of light and its not too hot or cold. Today its 75 in our garage which seemed to work out fine - the product did not dry too quick.
It takes time due to all the curved edges on the screen.
Don't be afraid to remove the product and start over.
Overall pretty pleased so far.
Attached are photos with the NAV completed. Only area left is just below the screen with the control buttons.
