41 - 60 of 581 Posts
I agree it does make sense. I thought of a reason for me not to do it though. I recently hooked up a aftermarket harness for my tow hitch (trailer lights) and one of the plugs plugs into the turn signal lights and none into the bottom reverse light. So if i want my trailer lights to work i can't do this. I'm ok with it. Hope you figure it out with Alfa but if it was me and wanted it bad enough $49 for Appcar wouldn't stop me. ;)
Anyone know what i would need to do to get auto high beams? From what i see i do have a camera in the rear view but i think its for the lane sense. I know this is a long shot but can that be used for the auto high beams or do i need a different mirror with a another camera located somewhere else. I see i can turn it on in AlfaOBD.
@Fishyguy I'm looking around for the auto high beams stuff for mine but keep seeing things that may be for your European turn signal thing. here's another to try.
CBC I/O Usage-Right Rear Turn Lamp Usage - RIGHT REVERSE LAMP #2
CBC I/O Usage-Left Rear Turn Lamp Usage - LEFT REVERSE LAMP #2
Does anyone know how to activate the trailer hitch on a 2014 Grand Cherokee using this app? The dealer wants $159 and I'm looking to try and do it myself before getting ripped off.
I didn't do this because I wasn't lucky enough to have the harness from factory so I can't confirm it will work but my guess would be to set each of these.
CBC Configurable Inputs and Outputs:
Trailer Backup Lamps Output Present: Set
Trailer Tail Lamp Relay Ctrl Output Present: Set
Trailer Turn_Stop Relay Ctrl LT Output Present: Set
Trailer Turn_Stop Relay Ctrl RT Output Present: Set
CBC Features Configuration:
Trailer Tow Present: Set
For anyone who wants to do the European style turn signal thing using AlfaOBD change the following settings.
Combined Rear Lighting Enable: No
CBC I/O Usage-Right Rear Turn Lamp Usage = Right Rear Turn Signal
CBC I/O Usage-Left Rear Turn Lamp Usage = Left Rear Turn Signal
It changes the outside reverse light (#2) to the turn signal
Thanks for this! What bulb size are those, so I can purchase yellow LEDs
I got theses from amazon. They are bright for sure and pretty cheap. Guy I know has had them in his GC for over a year and working great
iJDMTOY (2) No Resistor, No Hyper Flash 21W High Power Amber 7440 W21W T20 LED Bulbs For Car Front or Rear Turn Signal Lights
Okay, I'm very interested in doing this for my 2019 Grand Cherokee Trailhawk but have a few questions (sorry if they are a bit repetitive). Looking over the list I want to accomplish a few things off the top of my head, questions are bolded:
  • Disable DRL dropout
  • Change Tire Size: I have 265/65/18 now this will correct for that?
  • Disable noise cancelling (installing aftermarket exhaust)
  • Fog lights remain on with high beams
  • Enable LED usage without resistors: Does this mean I can use rear LED blinkers without resistors and don't get hyperblinking?
  • Monitor hood with alarm: I assume I have a factory alarm but how do you verify this?
  • Disable the Navigation lockout while driving, is this possible?
  • Change number of "blinks" when just tapping blinker stalk, is this possible?
  • Adjust the sensitivity of the automatic wipes, is this possible?
  • What is the Euro Tail Light function, any examples of this?
So judging from the initial post I need a ZAutomotive Bypass Module and preferably a OBDLink MX to connect to the OBD port and accomplish all of this.
