As you know, I picked up a 2000 JGC Limited with the 4.7 engine. He had all sorts of trouble with his (2) that he had in the past... Told me to youtube "4.7 timing chain replacement"
He also said that not all 4.7's are compatible if you happen to need to swap the engine. I can understand that.
So, at how much mileage should I look into doing the timing chains, guides and tensioners?
Also, any other thing to look out for?
Thanks.
Thanks.
