OEM Under Hood Light
8.4K views 17 replies 7 participants last post by  HemiRx
Somebody educate me. I just ordered an OEM mopar under hood light and wiring kit. It says it fits 1998-2017 Jeep Grand Cherokees and Dodge Rams. I assumed that meant there was an existing plug for the light in the engine compartment. I looked and can not locate one. The question is now, how is this gonna work? I used this same kit on a 2014 Dodge Ram with a 5.7L engine but the Ram had an existing plug for the light. What can I do with this kit?:confused:
#4 ·
Looking online all I see that fitting is the below...off Rock Auto using your 56021441AC number for the light itself...
JEEP GRAND CHEROKEE 1998-2001
JEEP WRANGLER 1998-2007
PLYMOUTH NEON 1998-2001
RAM 1500 2011-2017
RAM 2500 2011-2017
RAM 3500 2011-2017
RAM 4500 2011-2017
RAM 5500 2011-2017
#14 ·
I thought about using that positive post when I did mine but decided I wanted to keep the fuse inside the fuse panel. If I had used the positive post my plan was to drill and tap a threaded hole into the side of the big post and put a small bolt there so I could easily add stuff in the future.
#11 ·
THere were no existing holes. As I recall (was a year ago) I drilled a hole into the stiffening braces under the hood skin for the mounting screw. The lamp housing I used was off a 95 Caprice but looks similar to the genuine RAM one. I don't think the JGC ever had any factory provisions for an underhood light.
#13 ·
Yes, I think the part listing showed it would fit up thru 2012 so I assume up till then it was a factory option for some of the trim levels. I've never understood why manufacturers always wind up decontenting some of these little things as a particular model line ages even as they add newer gizmos to them.
