RRO Upper control arms - greasing?
5K views 7 replies 3 participants last post by  SRTabc123
I've got some RRO upper control arms installed in my 2019 Limited, for about a year now. There was some clunking sounds happening up near the front, which turned out to be loose UCA bolts which I just tightened. Since I tightened them, though, the clunking is gone but now there's a very loud and obnoxious creaking sound coming from the bushings. I can easily reproduce the sound just by standing outside the car and pushing down on the front end with my hands. Anyways, I'm thinking maybe the bushings are just dry and need grease. I didn't use any grease when I installed them, either (should I have? I don't recall the instructions saying to). Any thoughts? I don't want to grease them up and come to find out I shouldn't have. Likewise, I don't know if I should just slather grease all over them, or only in a few specific spots. Thanks
Reactions: PatientZero
#2 ·
I did grease the ball joints by the way - they came pre-greased originally, and I just squirted a ton more into the grease fittings, but that doesn't seem to be the source of the noise. I'm 99% sure it's the two rubber bushings (where the control arms mount to the chassis) that are squealing. Those bushings don't have grease fittings, didn't come pre-greased, and that's the part I'm not sure if I'm supposed to grease or not (and if so, then where and how?)
#3 ·
Anyone have any thoughts or advice, before I take my grease gun and just start jamming grease all in and around the chassis bushings?
#4 ·
See the thread below for a possible source of the creaking noise.
#5 ·
Thanks - I actually did have that creaking sound as well, and already replaced those brackets and bolts, which fixed it. But the new creaking is almost for sure coming from the UCA bushings, I can put my ear by them and lift the car up and down and hear them. And it started right after I re-tightened all the UCA chassis bolts.
So I found a YouTube video of a guy with a Lexus sedan of some sort, showing exactly the same UCA symptoms I'm having. He suggested spraying some silicone lubricant spray up into and around the bushings, and it seemed to immediate resolve his issue and he says the noise never came back after that. So I think I'm going to pick up a can of the stuff tonight and give it a try. Will report back here with my findings...
#7 ·
Update - I sprayed some silicone lubricant all over the UCA/chassis bushings, and also the sway bar/chassis bushings just for good measure (since it sounded like those might've been creaking a little as well). Hopped up onto my rock sliders and jumped around a bit to work the lubricant into the bushings, gave it a quick drive around the neighborhood, and the problem seems to be resolved! No idea how long it'll work for, but the giant can of silicone lubricant was only $6 and I'm just going to keep it in the trunk :D
With that problem resolved, it's time to start working on creating some new ones ;) We now resume our regularly scheduled programming over in my other thread about lifting my suspension more!
