281 - 293 of 293 Posts
Thanks for the reply. Right now I only have the hooks and brackets themselves. Everything on the left hand side of your picture is what I am missing (left of the passenger side hook).
I think you can get or fabricate the missing parts without too much trouble if you are a bit of a DIYer. Attached is the installation instructions of you don't have them. Shows what goes where.
If you don't have yours installed yet, would you be willing/able to get some measurements of the brackets that include the size of the holes, measurements on center for the holes, height of the rise of the bent brackets, and length overall? I'd also be willing to cover shipping both ways so I can have a metal fab guy out here measure and duplicate them, then they can be made whenever since I know there are so many people who need only these but are unable to get them. PM me and let me know if that is something you'd be alright doing, I can send you an email from my .gov account with a copy of my ID/license so you know I am not just going to gank your brackets.
It's installed already so no help there. The brackets look as much as a way to locate things during assembly as anything else, I'm not sure they add much if anything structurally. I think you could make some out of heavy plumbers strap or get a piece of galvanized sheet metal and cut to size and shape.. or maybe not even need them. It's the heavy bracket that you have already that does the heavy lifting. The only other part that might not be off the shelf is the hatted sleeves but I think regular sleeves with a thicker wall cut to the right length would work.
Check out this thread
Anyone have experience with Rough Country front tow hooks? I can’t find the Mopar ones in stock anywhere.
I just installed the rough country tow hooks on my 17 Limited a few weeks ago. I didn't have the tow hook cut outs so i bought the replacement lower facia piece with the cut outs for $40 or so from Mopar. The entire install process was super easy. Replacing the lower plastic bumper piece was very easy, followed this video for that part
and then once I had the lower bumper facia off of the vehicle, there were about 15 little clips on the back of the bumper holding in that plastic piece that I was trying to replace. Just popped those clips out with a screwdriver (gently), and then replaced with the new plastic piece.
After the quick bumper surgery, Installing the rough country tow hooks themselves took maybe 5-10 minutes tops. Used an impact drill, the kit was just 4 bolts total, there was literally nothing to it, bolted the tow hooks right into the existing holes in the frame. I haven't had any experience with the factory tow hook assembly, but from the looks of it, this rough country install is much much easier than the factory version. Honestly this entire process was even easier and faster than replacing the passenger side lowbeam headlight bulb...
228396
Hello, i have a problem. I have installed the winch mount and have junk the parts for install oem tow hook.
Now i don’t found the parts to install it, i can buy it . they must be sent to Italy but you would help me a lot because I can't find them.
write here or in pm please!
Hello all and Technosavant!
Thank you for this post, very very useful. Do you happen to have the part numbers for the components? I'm new in this and have not been able to identify all parts. I have the towhooks, but not item G, H, I, J (the spacer, spacer bracket, hex nut, cover plate) [http://site.justforjeeps.com/guide/82212095.pdf]. Many thanks in advance.
We've talked about it before, and tonight I went and did it- I had purchased the hooks, and decided to give it a go myself. I also documented the process with photos so you all can get an idea of how hard it is.
Here's the parts:
I went with the rough country tow hooks. They don’t need brackets or any other mounts. The connect directly to the frame. They come red but I stripped mine and had them powder coated to match my Jeep
I'm trying to add tow hooks to my "22 WK2 and just sent Mopar a message, most of the parts are still available for sale through Mopar, but I cant find the:
4 black brackets shown on the left
8 dark gray nuts shown on @jimntempe photo provided above
The 4 light gray longer bolts+washers shown aren't available via Mopar, but I did find them on Amazon
Does anyone know if sourcing these parts is still possible?
Would you mind sharing a picture of how they look paint matched?
How did you/the shop strip the red paint?
I haven't been able to find some of the brackets/nuts required for the Mopar tow hooks so this could be an alternative solution as I'm looking to add paint matched tow hooks as well.
I think your best bet is to check pick-n-pulls or Facebook marketplace for disassemblers. Any overland with the chrome tow hooks should have the brackets you are looking for. Found a full set of mopar skid plates off a wrecked ORA equipped wk2 locally for my brother’s jeep and it most likely had the brackets. They’re out there used now since they are most likely discontinued, I believe any 2011-2022 will work.
To add my 2 cents. I put the factory ones on and after looking at the complicated design of them compared to aftermarket like the rough country ones I theorize the factory made them complicated like that to comply with crash standards. If you look at how they would work as tow hooks compared to what they would do in an accident... as tow hooks they will just be in the right spot to load the bolts when you put tension on them. But in an accident they are made so the hooks can slide backwards an inch or so. It can't see where the factory would have make them that complicated unless they had to for some safety standard reason. So if you can't find factory parts I'd suggest just get aftermarket.
Just now
just seeing your response. If u still want pics I can post . I used aircraft stripper to take the red powder coat off
